Ok.C:\Program Files\Windows Sidebar\Gadgets\Clock.gadget
sfc /scannow Oops. 100% asks for reboot
leave or fix???
47
The file cbs.log shows some corruptions with system files which were repaired. As this machine is 15 years old lets have a look at the health of the harddisk.
Download CrystalDiskInfo.zip and save it on your desktop.
Extract the .zip file into a new folder.
In this new folder, run the tool DiskInfo.
When the tool is finished, it will show some information about the hard disc.
Note: Resize the window so that all information is visible.
Provide a screenshot of the result.
Edit:
Edit:
We will deal with that later. Please be patient.Leave or fix ?
49
Step 1:
WARNING! The following fix is specific to the user's system in this thread only. No one else should follow these instructions, as it could damage your system.
Step 2:
Follow the instructions below to run a scan with the System Update Readiness Tool (SURT) and provide a log.
- Download the attachment SFCFix.zip and save it on your desktop.
- Save any work you have open, and close all programs.
- Drag the SFCFix.zip file over the SFCFix.exe executable and release it.
- SFCFix will launch, let it complete.
- Once done, a file will appear on your desktop, called SFCFix.txt.
- Open the file, then copy and paste its content in your next reply.
Step 2:
- Download SURT for your system. (Windows 7 SP1 x64)
- Once downloaded, execute the installer, and go through the installation (this process can take around 15-20 minutes).
- On completion, a log will be created in C:\Windows\Logs\CBS\CheckSUR.log.
- Attach this log to your next reply.
51
Restart the computer.
Open an elevated command prompt.
Copy and paste the following command into it then press enter.
sfc /scannow
Wait for this to finish before you continue.
copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt"
This will create the file cbs.txt on your Desktop. Zip this file and attach the zipped cbs.txt to your next post.
This isn't work. I'm just a volunteer providing help whenever I have timeDoes Sunday work bother you?
sfc /scannow
53
It looks like SFC requires a reboot to complete some repairs.
Reboot the machine
After the reboot perform the instructions in this message again and provide the file cbs.log again.
What did the second screenshot tell us ?
Reboot the machine
55
- Download the attachment SFCFixScript.txt and save it on your desktop.
- Drag the SFCFixScript.txt file over the SFCFix.exe executable and release it.
57
Step 1:
sfc /scannow
sfc /scannow
58
My drivers flew off yesterday, I tried to restore 595, it gave errors. Raise the system from a copy, but will it also be there or without removable device drivers yet.I turned off the periphery, I do it your way.The system itself works. WiFi and IDA (infrared port) remained with yesterday's 4 mistakes. I do as you wrote.
no integrity violations found,and earlier these "recorded" files are found, the changes will take effect after the reboot, and I rebooted
YOU ARE A MAGIC MASTER,THANKS TO YOU AND ADMINISTRATOR AND PEACEFUL SKY !!!
