MiniToolBox by Farbar Version: 17-06-2016
Ran by Rob (administrator) on 05-02-2022 at 13:26:10
Running from "E:\Nieuwe cd\Windows Repair Utilities"
Microsoft Windows 8.1 Pro (X64)
Model: h9-1102ed Manufacturer: Hewlett-Packard
Boot Mode: Normal
========================= IE Proxy Settings: ==============================
Proxy is not enabled.
No Proxy Server is set.
========================= IP Configuration: ================================
Realtek PCIe GBE Family-controller = Ethernet (Connected)
Realtek RTL8723BE 802.11 bgn Wi-Fi Adapter = Wi-Fi (Connected)
Microsoft Network Adapter Multiplexor Driver = Network Bridge (Connected)
Bluetooth-apparaat (Personal Area Network) = Bluetooth-netwerkverbinding (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled
set interface interface="Network Bridge" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Windows IP Configuration
Host Name . . . . . . . . . . . . : Private
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : fritz.box
Ethernet adapter Network Bridge:
Connection-specific DNS Suffix . : fritz.box
Description . . . . . . . . . . . : Microsoft Network Adapter Multiplexor Driver
Physical Address. . . . . . . . . : E8-40-F2-08-12-89
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2001:981:b984:1:752b:f678:e8cf:ac14(Preferred)
Temporary IPv6 Address. . . . . . : 2001:981:b984:1b919:770d:8c4c(Preferred)
Link-local IPv6 Address . . . . . : fe80::752b:f678:e8cf:ac14%21(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.178.50(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : zaterdag 5 februari 2022 10:40:29
Lease Expires . . . . . . . . . . : dinsdag 15 februari 2022 10:40:29
Default Gateway . . . . . . . . . : fe80::9a9b:cbff:fea6:1359%21
192.168.178.1
DHCP Server . . . . . . . . . . . : 192.168.178.1
DHCPv6 IAID . . . . . . . . . . . : 401096946
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-29-8A-1B-70-C0-38-96-27-1D-29
DNS Servers . . . . . . . . . . . : fd00::9a9b:cbff:fea6:1359
192.168.178.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter LAN-verbinding* 13:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Physical Address. . . . . . . . . : C0-38-96-27-1D-29
Wireless LAN adapter LAN-verbinding* 3:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Ethernet adapter Bluetooth-netwerkverbinding:
Description . . . . . . . . . . . : Bluetooth-apparaat (Personal Area Network)
Physical Address. . . . . . . . . : C0-38-96-27-1D-2A
Tunnel adapter isatap.fritz.box:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Server: fritz.box
Address: fd00::9a9b:cbff:fea6:1359
Addresses: 2a00400e:810::200e
142.250.179.174
Pinging google.com [2a00400e:810::200e] with 32 bytes of data:
Reply from 2a00400e:810: time=12ms
Reply from 2a00400e:810: time=9ms
Ping statistics for 2a00400e:810:
Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 9ms, Maximum = 12ms, Average = 10ms
Server: fritz.box
Addresses: 2001:4998:24:1:1
2001:4998:24:1:0
2001:4998:44:8000
2001:4998:124:f001
2001:4998:44:8001
2001:4998:124:f000
74.6.143.26
74.6.231.21
74.6.231.20
74.6.143.25
98.137.11.164
98.137.11.163
Pinging yahoo.com [2001:4998:24:1:1] with 32 bytes of data:
Reply from 2001:4998:24:1:1: time=164ms
Reply from 2001:4998:24:1:1: time=156ms
Ping statistics for 2001:4998:24:1:1:
Minimum = 156ms, Maximum = 164ms, Average = 160ms
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Interface List
21...e8 40 f2 08 12 89 ......Microsoft Network Adapter Multiplexor Driver
18...c0 38 96 27 1d 29 ......Microsoft Hosted Network Virtual Adapter
7...c0 38 96 27 1d 29 ......Microsoft Wi-Fi Direct Virtual Adapter
3...c0 38 96 27 1d 2a ......Bluetooth-apparaat (Personal Area Network)
1...........................Software Loopback Interface 1
5...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.178.1 192.168.178.50 20
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.178.0 255.255.255.0 On-link 192.168.178.50 276
192.168.178.50 255.255.255.255 On-link 192.168.178.50 276
192.168.178.255 255.255.255.255 On-link 192.168.178.50 276
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.178.50 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.178.50 276
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
21 276 ::/0 fe80::9a9b:cbff:fea6:1359
1 306 ::1/128 On-link
21 276 2001:981:b984::/48 fe80::9a9b:cbff:fea6:1359
21 276 2001:981:b984:1::/64 On-link
21 276 2001:981:b984:1b919:770d:8c4c/128
On-link
21 276 2001:981:b984:1:752b:f678:e8cf:ac14/128
On-link
21 276 fe80::/64 On-link
21 276 fe80::752b:f678:e8cf:ac14/128
On-link
1 306 ff00::/8 On-link
21 276 ff00::/8 On-link
Persistent Routes:
None
========================= Winsock entries =====================================
Catalog5 01 C:\Windows\SysWOW64\napinsp.dll [55296] (Microsoft Corporation)
Catalog5 02 C:\Windows\SysWOW64\pnrpnsp.dll [70144] (Microsoft Corporation)
Catalog5 03 C:\Windows\SysWOW64\pnrpnsp.dll [70144] (Microsoft Corporation)
Catalog5 04 C:\Windows\SysWOW64\NLAapi.dll [65536] (Microsoft Corporation)
Catalog5 05 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog5 06 C:\Windows\SysWOW64\winrnr.dll [23040] (Microsoft Corporation)
Catalog5 07 C:\Windows\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
Catalog9 01 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 02 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 03 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 04 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 05 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 06 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 07 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 08 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 09 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 10 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 11 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [69120] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [88576] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [88576] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [86016] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [30720] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [63488] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
========================= Event log errors: ===============================
Application errors:
Error: (02/04/2022 06:00:01 PM) (Source: Application Error) (User: )
Description: Naam van toepassing met fout: rundll32.exe_winethc.dll, versie: 6.3.9600.17415, tijdstempel: 0x54504eb8
Naam van module met fout: USER32.dll, versie: 6.3.9600.20144, tijdstempel: 0x615be9b3
Uitzonderingscode: 0xc0000142
Foutmarge: 0x00000000000ed170
Id van proces met fout: 0x1eac
Starttijd van toepassing met fout: 0xrundll32.exe_winethc.dll0
Pad naar toepassing met fout: rundll32.exe_winethc.dll1
Pad naar module met fout: rundll32.exe_winethc.dll2
Rapport-id: rundll32.exe_winethc.dll3
Volledige pakketnaam met fout: rundll32.exe_winethc.dll4
Relatieve toepassings-id van pakket met fout: rundll32.exe_winethc.dll5
Error: (02/04/2022 05:59:41 PM) (Source: Application Error) (User: )
Id van proces met fout: 0x2154
Error: (02/04/2022 05:59:03 PM) (Source: Application Error) (User: )
Description: Naam van toepassing met fout: svchost.exe_stisvc, versie: 6.3.9600.17415, tijdstempel: 0x54504177
Naam van module met fout: unknown, versie: 0.0.0.0, tijdstempel: 0x00000000
Uitzonderingscode: 0xc0000005
Foutmarge: 0x00000000020007d0
Id van proces met fout: 0xa7c
Starttijd van toepassing met fout: 0xsvchost.exe_stisvc0
Pad naar toepassing met fout: svchost.exe_stisvc1
Pad naar module met fout: svchost.exe_stisvc2
Rapport-id: svchost.exe_stisvc3
Volledige pakketnaam met fout: svchost.exe_stisvc4
Relatieve toepassings-id van pakket met fout: svchost.exe_stisvc5
Error: (02/04/2022 05:58:48 PM) (Source: Perflib) (User: )
Description: rdyboost4
Error: (02/04/2022 05:58:47 PM) (Source: Perflib) (User: )
Description: BITSC:\Windows\System32\bitsperf.dll4
Ik krijg regelmatig de melding 'Netwerkbridge heeft geen geldige IP configuratie (zie bijgaande MTB-bijlage. Graag hulp
