7-Zip
Woudje100
07 mar 2010 15:50
7-Zip is a file archiver with a high compression ratio.
The main features of 7-Zip are:
  • * High compression ratio in new 7z format with LZMA compression
    * Supported packing / unpacking formats: 7z, ZIP, GZIP, BZIP2 and TAR
    * Supported formats for unpacking only: ARJ, CAB, CHM, CPIO, DEB, DMG, HFS, ISO, LZH, LZMA, MSI, NSIS, RAR, RPM, UDF, WIM, XAR and Z.
    * Compression ratio for ZIP and GZIP formats: 2-10 % better than the ratio provided by PKZip and WinZip
    * Strong AES-256 encryption in 7z and ZIP formats
    * Self-extracting capability for 7z format
    * Integration with Windows Shell
    * Powerful File Manager
    * Powerful command line version
    * Plugin for FAR Manager
    * Localizations for 74 languages
Woudje100
07 mar 2010 15:55
7-Zip 4.65
Changelog
  • - 7-Zip File Manager now can calculate SHA-256 checksum.
    - Some bugs were fixed.
7-Zip 9.10 Beta
Changelog
  • * The BUG in 7-Zip 9.09 beta was fixed: 7-Zip created incorrect ZIP archives, if ZipCrypto encryption was used.
Woudje100
17 mar 2010 09:25
7-Zip 9.11 Beta
Changelog
  • - 7-Zip now supports PPMd compression in .ZIP archives.
    - Speed optimizations in PPMd codec.
    - The support for archives in installers was improved.
    - New localization: Kazakh.
