Ik heb een dell Inspiron m731R laptop.
Hier heb ik windows 8 op gezet maar wanneer ik de driver voor draadloos internet erop wil zitten krijg ik een error
Dit log bestand krijg ik
- Spoiler: weergeven
- [01/13/15 17:59:43] Update Package Execution Started
[01/13/15 17:59:43] Original command line: "E:\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1).EXE"
[01/13/15 17:59:43] DUP Framework EXE Version: 3.0.93.1
[01/13/15 17:59:43] DUP Release: 8N59MX02-00
[01/13/15 17:59:43] Intializing framework...
[01/13/15 17:59:44] logo.png
[01/13/15 17:59:56] User Command: attended
[01/13/15 17:59:56] DUP Capabilities Value: 39845887 (0x25FFFFF)
[01/13/15 17:59:56] DUP Vendor Software Version: 10.0.0.255
[01/13/15 17:59:56] Local System/Model Compatible with this Package? Yes
[01/13/15 17:59:56] Local System OS Version: 6.2.0.0
[01/13/15 17:59:56] OS Compatible with this Package? Yes
[01/13/15 17:59:56] Local System OS Language: NL
[01/13/15 17:59:56] Language Compatible with this Package? Unknown
[01/13/15 18:00:04] Identified Behavior : attended
[01/13/15 18:00:04] Temporary payload log file name: C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)\DUP25CF.tmp
[01/13/15 18:00:04] Translated Command Line : Setup.exe /LOG"C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)\DUP25CF.tmp"
[01/13/15 18:00:04] Path : C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)
[01/13/15 18:00:05] Append Vendor Software Log: C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)\DUP25CF.tmp
[01/13/15 18:00:05]
--- Start of Vendor Software Log ---
[01/13/15 18:00:05] ASCII payload log file detected.
[01/13/15 18:00:05] [2015-1-13 18:00:05] Setup start up.
[2015-1-13 18:00:05] CommandLine is:[/LOG"C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)\DUP25CF.tmp"]
[2015-1-13 18:00:05] The current system isn`t supported.
[2015-1-13 18:00:05] Setup end.(10)
[01/13/15 18:00:05]
--- End of Vendor Software Log ---
[01/13/15 18:00:05] Vendor Software Return Code: 10
[01/13/15 18:00:05] logo.png
[01/13/15 18:00:05] Name of Exit Code: ERROR_INSTALL_PLATFORM_UNSUPPORTED
[01/13/15 18:00:05] Exit Code set to: 5 (0x5)
[01/13/15 18:00:05] Result: FAILURE
[01/13/15 18:00:10] Name of Exit Code: ERROR_INSTALL_PLATFORM_UNSUPPORTED
[01/13/15 18:00:10] Execution terminated at date-time 01/13/15 18:00:10
[01/13/15 18:00:10] ######
[01/13/15 18:05:33] Update Package Execution Started
[01/13/15 18:05:33] Original command line: "E:\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1).EXE"
[01/13/15 18:05:33] DUP Framework EXE Version: 3.0.93.1
[01/13/15 18:05:33] DUP Release: 8N59MX02-00
[01/13/15 18:05:33] Intializing framework...
[01/13/15 18:05:33] logo.png
[01/13/15 18:05:35] User Command: attended
[01/13/15 18:05:35] DUP Capabilities Value: 39845887 (0x25FFFFF)
[01/13/15 18:05:35] DUP Vendor Software Version: 10.0.0.255
[01/13/15 18:05:35] Local System/Model Compatible with this Package? Yes
[01/13/15 18:05:35] Local System OS Version: 6.2.0.0
[01/13/15 18:05:35] OS Compatible with this Package? Yes
[01/13/15 18:05:35] Local System OS Language: NL
[01/13/15 18:05:35] Language Compatible with this Package? Unknown
[01/13/15 18:05:43] Identified Behavior : attended
[01/13/15 18:05:43] Temporary payload log file name: C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)\DUP5032.tmp
[01/13/15 18:05:43] Translated Command Line : Setup.exe /LOG"C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)\DUP5032.tmp"
[01/13/15 18:05:43] Path : C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)
[01/13/15 18:05:43] Append Vendor Software Log: C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)\DUP5032.tmp
[01/13/15 18:05:43]
[01/13/15 18:05:43] ASCII payload log file detected.
[01/13/15 18:05:43] [2015-1-13 18:05:43] Setup start up.
[2015-1-13 18:05:43] CommandLine is:[/LOG"C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)\DUP5032.tmp"]
[2015-1-13 18:05:43] The current system isn`t supported.
[2015-1-13 18:05:43] Setup end.(10)
[01/13/15 18:05:43]
[01/13/15 18:05:43] Vendor Software Return Code: 10
[01/13/15 18:05:44] logo.png
[01/13/15 18:05:44] Name of Exit Code: ERROR_INSTALL_PLATFORM_UNSUPPORTED
[01/13/15 18:05:44] Exit Code set to: 5 (0x5)
[01/13/15 18:05:44] Result: FAILURE
[01/13/15 18:06:01] Name of Exit Code: ERROR_INSTALL_PLATFORM_UNSUPPORTED
[01/13/15 18:06:01] Execution terminated at date-time 01/13/15 18:06:01
[01/13/15 18:06:01] ######
[01/13/15 21:09:25] Update Package Execution Started
[01/13/15 21:09:25] Original command line: "E:\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1).EXE"
[01/13/15 21:09:25] DUP Framework EXE Version: 3.0.93.1
[01/13/15 21:09:25] DUP Release: 8N59MX02-00
[01/13/15 21:09:25] Intializing framework...
[01/13/15 21:09:25] logo.png
[01/13/15 21:09:33] User Command: attended
[01/13/15 21:09:33] DUP Capabilities Value: 39845887 (0x25FFFFF)
[01/13/15 21:09:33] DUP Vendor Software Version: 10.0.0.255
[01/13/15 21:09:33] Local System/Model Compatible with this Package? Yes
[01/13/15 21:09:33] Local System OS Version: 6.2.0.0
[01/13/15 21:09:33] OS Compatible with this Package? Yes
[01/13/15 21:09:33] Local System OS Language: NL
[01/13/15 21:09:33] Language Compatible with this Package? Unknown
[01/13/15 21:09:46] Identified Behavior : attended
[01/13/15 21:09:46] Temporary payload log file name: C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)\DUP67DD.tmp
[01/13/15 21:09:46] Translated Command Line : Setup.exe /LOG"C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)\DUP67DD.tmp"
[01/13/15 21:09:46] Path : C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)
[01/13/15 21:09:50] Append Vendor Software Log: C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)\DUP67DD.tmp
[01/13/15 21:09:50]
[01/13/15 21:09:50] ASCII payload log file detected.
[01/13/15 21:09:50] [2015-1-13 21:09:50] Setup start up.
[2015-1-13 21:09:50] CommandLine is:[/LOG"C:\ProgramData\dell\drivers\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1)\DUP67DD.tmp"]
[2015-1-13 21:09:50] The current system isn`t supported.
[2015-1-13 21:09:50] Setup end.(10)
[01/13/15 21:09:50]
[01/13/15 21:09:50] Vendor Software Return Code: 10
[01/13/15 21:09:51] logo.png
[01/13/15 21:09:51] Name of Exit Code: ERROR_INSTALL_PLATFORM_UNSUPPORTED
[01/13/15 21:09:51] Exit Code set to: 5 (0x5)
[01/13/15 21:09:51] Result: FAILURE
[01/13/15 21:10:06] Open file: C:\ProgramData\Dell\UpdatePackage\Log\5735_Network_Driver_8N59M_WN_10.0.0.255_A00 (1).txt
De internet driver heb ik hier gedownload http://www.dell.com/support/home/us/en/ ... erId=GMW8T
Wat doe ik verkeerd?
