daniel8970
adw
wo 16 aug, 2017 21:06:53
AdwCleaner 7.0.1.0 - Logfile created on Wed Aug 16 18:17:32 2017
# Updated on 2017/05/08 by Malwarebytes
# Database: 08-16-2017.2
# Running on Windows 10 Home (X64)
# Mode: scan
# Support: https://www.malwarebytes.com/support
***** [ Services ] *****
No malicious services found.
***** [ Folders ] *****
PUP.Adware.Heuristic, C:\ProgramData\{4B36989F-BE86-4A21-94B1-AC154A69EA65}
***** [ Files ] *****
No malicious files found.
***** [ DLL ] *****
No malicious DLLs found.
***** [ WMI ] *****
No malicious WMI found.
***** [ Shortcuts ] *****
No malicious shortcuts found.
***** [ Tasks ] *****
No malicious tasks found.
***** [ Registry ] *****
PUP.Optional.Legacy, [Key] - HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\mysearch123.com
PUP.Optional.Legacy, [Key] - HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\www.mysearch123.com
PUP.Optional.Legacy, [Key] - HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\DOMStorage\mysearch123.com
PUP.Optional.Legacy, [Key] - HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\DOMStorage\www.mysearch123.com
wat denken jullie van deze scan moet er verder nog iets gebeuren***groetjes daniël**********************
Re: adw
wo 16 aug, 2017 21:41:29
Zo te zien is er wat gevonden, maar uit dit logbestand blijkt niet dat je de gevonden items ook hebt laten verwijderen.
Dus voer AdwCleaner nog eens uit en klik na het scannen op Opruimen:
Wanneer je AdwCleaner al vaker hebt gedraaid, dan post je het bestand met het hoogste getal erin, bijvoorbeeld C:\AdwCleaner\AdwCleaner[C13].txt
Een security expert zal je daarna verder helpen in dit topic.
daniel8970
Re: adw
do 17 aug, 2017 20:24:28
is het normaal dar de verwijdering nog niet gedaan is na vier uur?
groetjes daniel
Re: adw
do 17 aug, 2017 23:35:28
Nee, dat is niet normaal. Ik zou AdwCleaner maar afsluiten, want 4 uur is veel te lang.
Ik ga ervan uit dat morgen een van de security helpers van dit forum jouw topic oppikt en jou verder zal helpen. Waarschijnlijk zal hij je een of meer andere programma's laten downloaden en gebruiken om daarmee te achterhalen wat er aan de hand is.
daniel8970
Re: adw
vr 18 aug, 2017 06:33:19
bedank voor uw antwoord
ik wacht dus af
groetjes
OS: Windows 10 64-bit
Re: adw
vr 18 aug, 2017 08:50:51
Hallo,  :welkom:
Ik heb je even verplaatst om je beter te kunnen helpen.
Groeten abbsAfbeelding
daniel8970
Re: adw
vr 18 aug, 2017 11:01:23
alles uitgevoerd zoals gevraagd
Re: adw
vr 18 aug, 2017 12:27:11
Verwijder je oude Java's, via "Programma's en onderdelen":
Java 8 Update 101
Java 8 Update 111
Java 8 Update 121
Java 8 Update 131
Java 8 Update 141
Herstart je pc en installeer de nieuwste Java: https://www.java.com/nl/download/
  • Druk op de Fix knop
daniel8970
Re: adw
vr 18 aug, 2017 20:24:00
in bijlage het gevraagde
groetjes
Daniël
Re: adw
vr 18 aug, 2017 21:50:58
Dit is niet goed gegaan je heb gescand met Farber Recobvery Scan Tool, je had de fix uit moeten voeren dus les de instructies goed door.
daniel8970
Re: adw
za 19 aug, 2017 07:04:37
hopelijk heb ik het nu goed gedaan
groetjes,
Daniël
Re: adw
za 19 aug, 2017 10:20:25
Dat is netjes doe weer eens een scan met AdwCleaner en plaats de uitslag als bijlage.
daniel8970
Re: adw
za 19 aug, 2017 18:08:48
de gevraagde scan
groetjes,
Daniël
daniel8970
Re: adw
za 19 aug, 2017 18:20:11
opnieuw scan gedaan na opruiming toegepast te hebben
die is vlot verlopen
bedank voor uw hulp
groetjes
Daniël
Re: adw
zo 20 aug, 2017 10:23:42
Dat is netjes zo als er verder geen problemenmeer zijn doe de laatste stap:
  • Remove disinfection tools
