corweb
OS: windows 10
AV: kaspersky 16.0.0.614 (a)
AM: c-cleaner/adw-cleaner
FW: kaspersky
adw-cleaner
di 08 sep, 2015 07:22:05
het valt mij op dat internet explorer niet meer wordt meegenomen in de scan van AdwCleaner, alleen Firefox en chrome.
hoe is dat te herstellen ??
Re: adw-cleaner
di 08 sep, 2015 09:14:01
Hallo en welkom op het forum,
Het tabblad Internet Explorer is sinds versie "v5.000" niet meer aanwezig, alle items van Internet Explorer worden nu onder het tabblad "Registry" weergegeven.
Hieronder een overzicht van de complete changelog met alle veranderingen sinds versie 5.000.
[NEW] - Debug mode added
[NEW] - New generic detections engine
[NEW] - Quarantine manager is now fully integrated into AdwCleaner
[NEW] - Compatibility with W10
[NEW] - "Reset Proxy settings" option added
[NEW] - "Reset Winsock settings" option added
[NEW] - "Reset TCP/IP settings" option added
[NEW] - "Reset Firewall settings" option added
[NEW] - "Reset IPSec settings" option added
[NEW] - "Reset BITS queue" option added
[NEW] - "Reset Internet Explorer policies" option added
[NEW] - "Reset Chrome policies" option added
[NEW] - Generic.BrowseFox added to generic detections
[UPD] - Local database v14-08-2015.3
[UPD] - Code optimization
[UPD] - SQLite version updated to v3.8.11.1
[UPD] - Chrome preferences detection improved
[UPD] - "HKLM\SOFTWARE\AppDataLow\Software" added to handled keys
[UPD] - "HKCU\Software\Microsoft\Internet Explorer\Toolbar\ShellBrowser" added to handled keys
[UPD] - "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Ext\CLSID" added to handled keys
[UPD] - "HKEY_USERS" subkeys added to handled keys
[UPD] - "Generic.Netfilter" renamed to "Generic.Vitruvian"
[UPD] - All generic detections updated
[UPD] - Tasks detection improved (x64 folders handled)
[UPD] - AppInit detection improved (x64 values handled)
[UPD] - Infected shortcuts detection improved (recursive search)
[UPD] - Auto-resize for all columns in GUI
[UPD] - "Files / Folders" report sections split
[UPD] - Reports are now saved to C:\ instead of C:\AdwCleaner
[UPD] - Searching reports are now called "AdwCleaner[SX].txt"
[UPD] - Cleaning reports are now called "AdwCleaner[CX].txt"
[UPD] - New caption in cleaning reports :
[-] : The element has been deleted
[+] : The element has been deleted after resetting its ACL
[#] : The element will be deleted on reboot
[!] : The element can't be deleted
[x] : The element has not been marked for deletion
[REM] - "Internet Explorer" tab removed (keys are now listed in "Registry" tab)
[REM] - Illyx generic detection removed
[REM] - Gomita generic detection removed
[REM] - Skintrim generic detection removed
[REM] - Pirrit generic detection removed
[REM] - Maintainer generic detection removed
[REM] - AdPeak generic detection removed
Gebruikers op dit forum: Geen geregistreerde gebruikers en 6 gasten
