FBI Moneypack virus / Trojan.Ransom verwijderen
wo 16 jan, 2013 11:00:28
All activity of this computer has been recorded
If you use a Webcam, videos and pictures were saved for identification.
You can be clearly identifiet by resolving your IP address and the associated hostname.
Illegally downloaded material (MP3's, Movies or Software) has been located on your computer.
By downloading, those wore reproduced, thereby involving a criminal offense under Section 106 of the Copyright Act.
The downloading of copyrighted material via the Internet or music- sharing networks is illegal and is in accordance with Section 106 of the Copyright Act subject to a fine or imprisonment for a penalty of up to 3 years.
Furthermore, possession of illegally dov.nloade.d material is punishable under Section 184 paragraph 3 of the Criminal Code and may also lead to the confiscation of the computer, with which the files were downloaded.
unlock computer:
To unlock your computer and to avoid other legal consequences, you are obligated to pay a release fee of $200. Payable through GreenDot Moneypak. After successful payment, your computer will automatically unlock.
Failure to adhere to this request could involve criminal charges and possible imprisonment.
To perform the payment, enter the acquired GreenOot Moneypak code in the designated payment field and press the "Submit" button.
Removal Instructies
1.Download "HitmanPro" via de onderstaande link bijvoorbeeld naar het bureaublad op een niet geïnfecteerde computer
Klik hier om de uitgebreide handleiding te raadplegen
Klik hier om de handleiding voor het uitvoeren van HitmanPro.Kickstart via een Boot-CD
  • HitmanPro downloaden.(Kies hier de 32 of 64 bit versie).
  • Dubbelklik op HitmanPro36.exe of HitmanPro36_64.exe om het programma op te starten.
  • Klik in het beginscherm op de "Kickstartknop" zoals u kunt zien in het onderstaande rode kader.
  • Nadat de HitmanPro Kickstart USB-stick is aangemaakt zal deze automatisch “veilig verwijderd” worden van het betreffende systeem waarop deze is aangemaakt.
  • Start de geïnfecteerde computer op van de HitmanPro.Kickstart USB-stick. (Hoe u de computer van een USB-stick kunt opstarten lees u hier)
    Post dit logje.
DDS - Infospyware.
  • DDS.txt
Aangemaakte bestanden
C:\Users\Gebruikersnaam\wgsdgsdgdsgsd.exe
C:\ProgramData\dsgsdgdsgdsgw.pad
C:\Users\Gebruikersnaam\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\runctf.lnk
C:\Windows\System32\rundll32.exe c:\users\Gebruikersnaam\wgsdgsdgdsgsd.dll,H1N1
Re: FBI Moneypack virus / Trojan.Ransom removal
wo 16 jan, 2013 13:03:11
Removal Instructies
1. Please download HitmanPro to your desktop.
Press this link for the complete "User Manual" for HitmanPro.Kickstart.
  • Launch the program by double clicking on HitmanPro.exe. (Windows Vista/7 users right click on the HitmanPro icon and select run as administrator).
  • Click on the "HitmanPro.Kickstart button to create a bootable USB-stick with HitmanPro.Kickstart
  • Now insert the USB flash drive that will be used to write the HitmanPro.Kickstart files to.
    • As soon as one or more USB flash drives are detected, a selection screen will be presented.
  • Now select the USB flash drive on which you want to place the HitmanPro.Kickstart files and press the button Install Kickstart.
  • Importtant! Be aware that that all contents of the selected flash drive will be erased before the HitmanPro.Kickstart files are written.
  • If you press the ‘Yes’ button now, the selected USB flash drive will be formatted and all necessary HitmanPro.Kickstart files will be retrieved from the HitmanPro servers and written to the flash drive
  • Once the process is completed you can now remove the USB flash drive from the PC and use it to remove the malware from a ransomed PC.
  • Now insert the HitmanPro.Kickstart USB flash drive into a USB port of the ransomed PC and start the PC.
  • During the startup of the PC, enter the (BBS) Bios Boot Selector menu and select the USB flash drive that contains HitmanPro.Kickstart to boot from.
    • If it's not possible to enter the BBS go into the BIOS and set the USB option as your first boot-device by the boot-sequence.
  • The default way to boot is option 1, which skips the master boot record of your hard drive. If you do not press any key, the process will continue after 10 seconds using the default boot selection.
  • If you see a logon screen you can either select a user and logon, or if you wait approximately 15 seconds, HitmanPro will be started on your Windows logon screen.
  • Click on the next button. You must agree with the terms of EULA.
  • Check the box beside "No, I only want to perform a one-time scan to check this computer".
  • The program will start to scan the computer. The scan will typically take no more than 2-3 minutes.
  • Click on the next button and choose the option activate free license
  • Click on the next button and the infections where will be deleted.
  • Click now on the Save Log option and save this log to your desktop.
  • Click on the next button and restart the computer.
  • Copy the information of HitmanPro_20130116_1239.log in your next reply
2. Download DDS and save it to your desktop from here or here or here.
Disable any script blocker, and then double click DDSto run the tool.
  • When done, DDS will open two (2) logs:
    1. DDS.txt
    2. Attach.txt
  • Save both reports to your desktop.
Please include the following log in your next reply:
  • Contents of the DDS.txt posted as text in your reply
Start a new thread in this forum and copy and paste or attach both logs in your next reply.
