FBI trojan.ransom verwijderen [FBI warning your computer is Blocked for violation of Federal Law]
Gegeven likes: 4
Ontvangen likes: 6
09 okt 2012 12:37
Politie virus [Trojan.ransom] International Police Association - IAC
ATTENTION !
Your PC is blocked due to at least one of Me reasons specified below.
You have been violating Copyright a. Related RightS Law Wide, Music, software, a. illegaly using or distributing copyrighted content, thus infringing Article .
I. Section 8. Clause 8, also known as the copyright of the criminal code of United States of America.
Article I, Section 8, Clause 8 of the criminal code provides for a fine of two five hundred minimal wages or a deprivation of liberty for two to eight years.
You have been viewing or distributing prohibited Pornographic content (Child Prono / Zoofilia etc). Thus violating article 202 of the Criminal Code of united States of America. Article 202 of the criminal code provides for a deprivation of liberty of four tot twelve years.
Pursuant tot the amendement tot the Criminal Code of United States of America of May 28, 2011, this law infringement (if it is not repeated - first time) may be considered as conditional in case you pay the fine of the state.
Fines may only paid within 72 hours after infringement. As soon as 72 hours elapse, the possible tot pay the fine expires, and a criminal case is initiated against you automatically within the next 72 hours!
To unblock the computer, you must pay the fine through Moneypack of 200$.
How do I unlock computer using MoneyPak?
1. Find a retail location near you.
2. Look for a MoneyPak in the prepaid section. Take it to the cashier and load it with cash. A service fee up to $4,95 will apply.
3. To pay fine, you should enter the digits MoneyPak resulting code in the payment form and press Pay MoneyPak.
When you pay the fine, your PC will get unlocked in 1 to 4 hours after the money is put into the state's account.
In case an error occurs, you'll have to send the code by email fine@fbi.gov
Video
Removal Instructies
Stap 1
Start de computer op in de veilige modus met command / opdrachtprompt.
Zodra het systeem is opgestart in de veilige modus met de command / opdrachtprompt, typt u in dit venster explorer.exe gevolgd door enter.
Klik bij de melding Windows wordt nu in de veilige modus uitgevoerd op enter.
Nu zal het bureaublad, inclusief de taakbalk verschijnen zodat u het systeem normaal kunt gebruiken om de malware te verwijderen.
Note! U zult echter geen verbinding hebben met het internet, zet de te gebruiken tools met behulp van bijvoorbeeld een USB-stick over naar de geïnfecteerde computer.
Stap 2
Download MalwareBytes' Anti-Malware (website) en sla het op je bureaublad op.
  • Je krijgt hier ook de keuze om de evaluatie versie van MBAM te gebruiken, indien je dit niet wilt vink dit dan uit.
Klik daarna op "Voltooien".
Stap 3
DDS - Infospyware.
DDS zal 2 logfiles openen:
* DDS.txt
* Attach.txt
Plaats de logs van MalwareBytes' Anti-Malware en DDS in een nieuw onderwerp op het forum.
Technische details
Register
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
"Microsoft Updater"="C:\Documents and Settings\Gebruiker\Application Data\System\a630035382e022eccdf9d1ac4d95851cdad5ad492f2b2ffb1a8bc4a93ec0825d.exe"
[HKEY_USERS\S-1-5-21-854245398-1220945662-725345543-1003\Software\Microsoft\Windows\CurrentVersion\Run]
Aangemaakte mappen
Aangemaakte bestanden
C:\Documents and Settings\Gebruiker\Application Data\System\1.mp3
